- Sep 23, 2012
Hello everyone,
My system is as follows:
Ultra 200S Boost OC enabled
XMP enabled (CL32-39-39-102 1.40V Profile)
RAM Mode: Performance
When I run stability tests (AIDA64 Stress Memory Test, Prime95 Blend) on this system, I get memory-related errors. The memory modules are officially listed as compatible with the 200s boost overclock profile.
Gskill F5-6400J3239G16GX2-TZ5RK RAM modules are listed as compatible with the 200s boost profile in the Intel® XMP 3.0 Memory Datasheet and are also listed in the MSI 200 series upgrade list. Interestingly, before using G.Skill RAM, I had ADATA XPG AX5U6400C3216G-DCLARBK RAM when I first built the system. I initially encountered memory errors with them as well. Thinking the problem was with the memory, I switched to G.Skill RAM, but the problem persisted.
RAM modules from both brands are listed as compatible with the MSI 200 series Boost.
Sequence of events
a) This issue occurred on the evening of September 22, 2025.
Around 10:00 PM, my computer was working normally. I was watching a video on YouTube with the Edge browser open. While browsing forums on a different page, the system crashed. The system restarted, and the system crashed a second time under the same scenario. I started stability tests. I got a hardware error in the memory tests.
I ran the Windows 11 24H2 sfc /scannow test and found no software issues on the Windows side.
b) On the evening of September 23, 2025,
I came home from work.
I did not encounter any hardware errors or interruptions to the test.
It is unknown whether the issue stems from incompatibility with the Intel 200s profile, MSI BIOS, or Windows, but there is an incompatibility problem. This causes random BSOD errors. If it were hardware-related, I would have definitely encountered an error during last night's 4-hour test.
https://www.intel.com/content/www/u...mory-for-intel-core-processors-datasheet.htmlhttps://www.gskill.com/product/165/374/1642064699/F5-6400J3239G16GX2-TZ5RK-F5-6400J3239G16GA2-TZ5RKhttps://download-2.msi.com/archive/mnu_exe/mb/cpu_installation/MSI-200S-Boost-list.pdf
@Alan J T
@RemusM
@Pangolin
@darkhawk
- Motherboard: Msi MAG Z890 Tomahawk Wifi - AMI BIOS7E32v1A90 Installed
- Processor: Ultra 7 265K
- RAM: Gskill 32GB (2x16GB) Trident Z5 Black DDR5 6400MHz CL32 1.4V
- PSU: Asus Rog Strix 1000w Atx 3.1 Pci Gen 5
- GPU: Zotac RTX 5070 Ti
- Windows 24H2
Sequence of events
- AIDA 64 CPU and Memory Stability Test: 45 minutes
- Windows memory recognition test
- Memtest86 4-phase test 2 hours 15 minutes
@Alan J T
@RemusM
@Pangolin
@darkhawk
