MAG Z890 TOMAHAWK WIFI - Cold boot - lost settings
Jerome.DJe
Hello guys and girls,
i probably have same problem : https://forum-en.msi.com/index.php?...r-a-cold-boot-then-reboot-into-system.361971/
I use AMI BIOS7E32v1A41(Beta version) and test with N-1 bios => have the same problem.
I have change battery MB (date :2035 year)
No overclocking for DDR5
MB boot, 4-5s, shutdown, reboot and go to windows 11 with flat settings (ex: Fan)
If you have some idea.
Have a good day
  • HWiNFO64_HTML_FILE.zip
A new Beta BIOS was released today, V.1A45 with a release date of 11/29/2024. I have not installed it yet but will sometime today. I don't know where to go to read the change log to see if it addresses the issue related to this thread.
Yes, I realized it after reading the article. I will try it as soon as I get a chance and write the result.
Today i quit 1 hour, and motherboard boot normally after cold boot, bizarre. I change nothing.
Do you have sometime "this problem" ?
Can we target the problem when checking the ram ? or another component ?
P.S : I don't have the latest bios
Sometimes there is no problem after 1-2 hours. The important thing is that it works without problems after 4-5 hours. I also loaded the new bios, there is no change.
In manual we have :
code 92: PCI Bus initialization is started
white LED :GPU is not detected or fail
I dont know if we have conflict with initialization "CPU/GPU" with RTX4090
On my system, if the PC is powered off and immediately powered on again, the BIOS resets to default. The length of time powered off makes no difference. Why some systems react differently is certainly surprising.
By the way, after installing the latest BIOS v.1A45, my PC BIOS does not reset after waking from sleep mode. A little progress at least.
I installed the eSIO FW update and did a cold boot on my PC and it booted as expected. Glad that the issue is resolved.
Thank you, Pangolin for bringing the firmware update to our attention.
Help me! MSI Center detects the eSIO FW update, apparently installs it and restarts the computer, but when I restart MSI Center tells me that version 00 is still installed and not 02.
it solves the BIOS settings lost problem :confused2: a lot of chip has its own firmware, your GPU, LAN chip, superIO, PWM IC, BIOS, not exactly sure what you wanna know.
Try to reflash latest bios, reset it, and restart msi center to update ESIO FW
