msi.dagger69129602a1
- Apr 14, 2026
Anyone have the answer to this issue?
Can't get more than two monitors to run on this £1200 board via the iGPU.
M.2_2 slot is populated and at auto in the bios and I expect it to run at Gen 5*2 leaving still 2 lanes available for the USB4. Plenty of bandwidth.
If I attach a Thunderbolt Dock and monitors after POST it cannot negotiate a link regardless of whether or not the other spare USB 4 is a direct connection to a monitor. My understanding is this is largely expected behaviour for a TB dock on an AM5 consumer board as the TB stack is not available via firmware until the OS loads. The lack of a 3rd direct attached monitor available at POST though to allow access to bios and to login to the OS is odd??
I have tried multiple permutations of docks/splitters that aren't thunderbolt. Same issue.
My 9950x3D iGPU can run a ton of 4k@60Hz theoretically, but something about the DP alt mode isn't working on this board. It's like no more than 2 "DP lanes"(terminology?) will be allocated to screens. The bandwidth of theoretical 80gbs total and being unable to use it for a dock/splitter/daisy chain multi monitor setup that does not require manual hot plugging seems outrageous for a Mobo at this price point.
The ability to manipulate this stuff in the bios is also virtually non existent too. I've tried IGD force with 4UMA etc and still nothing. I do have eGPUs available, but I don't want to waste VRAM on displays for an AI machine that will be right on the edge of model capacity.
I bought this board due to its size and the 80gbps of USB 4 bandwidth for multi monitor setup via the iGPU leaving my eGPUs for other work.... So far it is a monumental waste of money if I need to compromise on that and I'm very disappointed in aspects of basic stability given the price point.
It seems like the USB4 firmware for POST is terrible at negotiating what it needs to to even give me 1 usable monitor if something other than 2 directly plugged in 4k monitors are used. 1 monitor for each usb4 port. Anything other than that and you get issues.
Any solutions to this or common banana skins. This MUST be a known issue.
Kind Regards
Kind Regards
