Meg CoreLiquid S360 Fan Control Speed Problem
Status
Not open for further replies.
Hello Everyone,
I bulid my new PC. After install all necessary driver I install MSI Center. In CoreLiqid/Fan Setting I set Balance Mode and not everyting go well. All fan spinning, but on the screen CPU temp stuck at 0 degree. When I try to load the CPU with Cinebench R23 HwMonitor in 100% load show 80 degree on CPU, but the cooler not reacted. All fan spinning the same speed as before. Could
someone help with tha issue? I try to reinstall MSI Center with no result.
Same issues here. CPU frecuency and CPU temp stuck at 0 mhz/degree. I am in 3.0.0.63 version. Two version before it was runnning with no problems.
Can you please post any comments on this topic to do with the AIO pump not running and CPU frequency and CPU temp stuck at 0 MHz/degree
To the Post linked here
https://forum-en.msi.com/index.php?threads/msi-meg-coreliquid-s360-problem.394335/
A lot did happen today. I was unable to find a download to reinstall v2.0.21 so I am stuck on v2.0.25 until the new version is available next month. Hope it released soon in November.
Svet,
thank you for taking the time to look into this issue.
Is the temporary workaround for non-MSI MB only?
I have had issues with v.2.0.25 MSI Center but I have a MSI Z790 Tomahawk DDR5 WIFI MB.
Problem Event Name: APPCRASH. Application Name: CC_Engine_x64.exe for example.
Thank you again for your time and expertise on these forums.
It Should work with MSI Boards
Humm will v2.0.22 do
Will drop a link when I have it uploaded
MSI_Center_2.0.22.0
I do not have 21 and I'm still on 22 for now till it gets around to auto-update
do no thave
You are too kind, thank you.
I am glad to try v.2.0.22, if problems persist, I'll try the patch on v.2.0.25.
The problem I have with v.2.0.25 (in addition to the CC_Engine_x64.exe appcrash) is the GPU fans "freeze" at a certain RPM and a restart is required to "unfreeze" them.
Same problem here. i'm getting blue screen since i'm using my 7950x at 100% (compiling programs).
i have removed the coreliquid S360 and put a cheap thermal solution.
I also suffer from the issue since MSI Center was automatically upgraded from version 2.0.21.0 to 2.0.25.0.
I have MSI motherboard Z790 CARBON WIFI.
MSI Center doesn't show the "Monitoring" page with CPU temperature. Coreliquid doesn't spin up the fans when CPU temperature increases.
Installing version 2.0.22.0 didn't help. Applying ccengine patch didn't help. 🤬
Can anybody please share a link for downloading MSI Center 2.0.21.0? 🙏
About this issue:
The issue was duplicated and will be fixed by MSI with next MSI Center, which is scheduled to be released in November.
As a temporary workaround you can use those steps:
Link: https://drive.google.com/drive/folders/1K79dikyOY9w2LIJGZd73rQdBc34hgm0i?usp=sharing
1. Download and unzip “Patch_CC_Engine.zip”
2. Run “go.bat”
3. Restart the system
Okay, this fixed it! You gave us a good scare today: a water cooler that cannot read your CPU temperature is a bad thing.
About this issue:
2. Run “go.bat”
Noticed something was wrong only after i smelt what seemed like burning from my computer... Even bluescreened when i alt f4'd out of my game with settings at max. This patch worked but why is it not being pushed immediately? Whatever update caused this problem turns the cooler into a deathtrap for cpus on the default MSI center fan settings. Nobody is going to be watching their temps all the time and because it is an update, more people will go on without noticing until it is too late. This needs to be addressed immediately.
MEG Coreliquid S360
I installed v2.0.22 thanks to Svet after I was auto-updated to v2.0.25. V.2.0.22 didn't run perfectly but was the best option. Today I was auto-updated to v.2.0.25 (despite auto-update turned off) by MS Store and MSI Center works perfectly. I am at a loss to explain. MSI Center at start-up indicates there is an update available. I'll pass on the update for now. LOL
Automatically updated to 2.0.26 and everything stopped working again, I turned off automatic updating. They want my computer to burn?
I would stay on V-2.0.22.0 and disable auto update it should prevent the update
Status
