Meg X570 Unify doesn't post with ram anything higher than 3200mhz with a Ryzen 5800x
Migx
I have a Trident Z Neo DDR4-3600MHz CL16-16-16-36 1.35V 32GB (2x16GB) kit.
I got this motherboard along with a 5800X processor yesterday. The pc won't post if I use the memory higher than 3200 mhz.
Is this going to be fixed at some point or should I just return the motherboard while I can?
I say this very bluntly because lots of people have been having this problem and apparently someone else with the same issue got a ticket response from msi saying 'sorry the new cpu's are only guaranteed to work up to 3200mhz" when we all know that every other brand of motherboards has been having no issues of running compatible memory at their advertised XMP speed. Every review of the new cpu's has been running at least 3600mhz ram. Hell, the last news piece on the msi website brags how they got their memory running at 4200mhz with the new cpus: https://www.msi.com/news/detail/26d2ac2a2d21cce1fdc682bda01ab066
This is a bad decision. If UCLK = 1/2FСLK, then 3800MHz memory will work slower than 3200MHz with UCLK = FCLK.
Considering that the FCLK is blocked no higher than 1600, the memory must be manually set on 3200, and then the timings must be optimized. This will give the best performance effect.
Well, or buy Intel, as some advise :)
I agree with you, 3200 mhz for now is the best option. Give MSI a couple weeks and they will get it worked out. My G.Skill 14CL 3200Mhz ram works just fine as is. I am just looking forward to being able to utilize the 2000Mhz FCLK AMD is promising.
In regards to they buy intel... Meh, I was an intel fan boy for a long time but AMD has been very good to me, this is not really an AMD issue anyway, it's an MSI one, so if anything it's buy ASUS lol.
I just contacted MSI customer support regarding this issue and it does look like a BIOS related issue but of course they don't want to do anything about it right now. I got 'keep an eye on the BIOS page and I'm sure they will release soon' as a response.
My solution is also to manually underclock the FCLK to 1600MHZ and it works fine for now. Also make sure the UCLK is not set to 1=1 ratio. Not an ideal solution and you really are not benefitting from the faster RAM speeds if that is the case, but at least I can boot.
Hopefully MSI gets something going quickly.
It also looks like the BETA Bios are up, I'm going to try that now and hopefully get something going. If it helps, I will update.
BETA Bios E7C35AMS.A75 made no difference from what I can tell. Not sure what changed, but it didn't resolve the FCLK issue.
And here I was thinking I made a good decision ordering the Tomahawk (b550) for my 5800x. *sigh*
Do you guys think this is getting fixed in the next week or two or should I just return the Tomahawk and go with a different brand?
No guarantee you won't have the same problem with a different brand or even worse problems.
This is a pretty true statement. It’s easy to just throw MSI under the bus but other brands are having issues too. Asus and Asrock seem to have fewer it seems but also as a whole it seems x570’s are the major culprits. B550 complaints seem to be fewer.
You could change to be safe but you got a really good board coming and most good boards are expensive right now due to the new CPU hype.
Same issue here
XMP profiles not working resulting in computer not starting up
Setting RAM speed manually to 3200MHz seems to work but everything above delivers the same result as setting xmp profiles
- MSI Unify X570 (BIOS 7C35vA7)
- Crucial Ballistix 64GB Kit (2 x 32GB) DDR4-3600 (BL2K32G36C16U4B)
- AMD Ryzen 5800X
- Radeon RX 580
For me Bios-downgrade to version 7C35vA6 seemed to solve this issue.
I can activate the xmp Profile now and memory runs with 3600MHz.
But the 7C35vA6 BIOS is based on the AGESA 1.0.8.1, does it support the 5000 series completely?
Do the benchmark results confirm that higher memory frequencies resulted in better performance?
hello everyone,
i have the same problem with my X570 MEG Unify and the Ryzen 9 5900x. With the BIOS version 7C35vA7, the XMP profile doesn't work at all with my G Skill F4-3600C16. Only with a downgrade to version 7C35vA6 is XMP activation possible via detours. I hope there will be a new bios update very soon so that everything works properly again. The same system works with the Ryzen 7 3700x without any problems
Anyone tested: E7C35AMS.A81?
Where did you get this version?
is still listing 7C35vA7 as latest version.
Beta BIOS goes up to FCLK 1900 for me, beyond that same 07 error. But given that my RAM is only rated for 3600 MHz, running it at 3800 MHz seems sufficient
Make sure you manually refresh the BIOS page as it not do it automatically so will just show what was there last time you looked.
I have this board and today I upgraded from a 3900 to a 5900 using the A81 bios update file. Everything seems to be working okay at the correct RAM speeds however I cannot adjust the ARGB settings on my G.Skill Trident Neo sticks. The G.Skill software doesn't even detect them, so they're stuck in the default rainbow cycle mode. Is this a known issue that's being worked on?
Thanks!
