MEG Z490 unify - Fan of Rear I/O Panel
Status
Not open for further replies.
rv12d302b1
What is the procedure for replacing the fan built into the cover of the Rear I/O Panel of motherboard?
Is there any instruction?
I can't find any :(
Hi
There isn't. I don't think MSI assumes a failure of it. Or maybe it's not something user should ever replace themselves (who knows what they've done exactly).
You most likely need to remove the VRM heatsink and everything around it, and that should get you access to the fan.
HAve a look at this video just the first few minutes
Will be same setup as your model
Status
