MEG Z590 Ace with 11900k overclocking advice
Status
Not open for further replies.
tpearce19712a302b0
Hi all
I’ve searched Google and YouTube and can’t seem to find anyone who’s got a detailed guide to OC this combination. I can just hit auto on everything and let the voltages (and heat) soar but I’d prefer to have a more tuned and focused setup.
Usually MSI does a YouTube guide with the latest X900k CPU but there isn’t much on the 11900k, especially with the MSI mother boards
My system is
MEG Z590 Ace
11900k
32gig Crucial Ballistix Max @ 4000
RTX 3090 Gaming X Trio
Corsair 1000w platinum
Corsair H150i Pro RGB XT
Thanks in advance for any help
badboy2k
with newer CPU's they are already nearly at the Ragged edge of what they can do out the box of there frequancy that is attainable. at most there may be 100Mhz there and to even get that you would have to up the voltage alot meaning alot more heat to get it stable.
the reason for no video is the above as there already nearly Maxed out out the box so there is absolutely no point anymore as there is nothing to increase unless you want to basically turn your CPU into a space heater.
D
Deleted member 663924
Guest
11900K no need OC ,.,.when works adaptive BOOST clock all run on MAX
and all core OC --extreme voltage "5ghz -on limit 1.52V" --absurd
use "stock" setup - performance is identical ;)
edit ,..,you need more ??
11900K
  • Processor Base Frequency 3.50 GHz
  • Max Turbo Frequency 5.30 GHz
  • Intel® Thermal Velocity Boost Frequency 5.30 GHz
D
Guest
you have to keep in mind "no limit" + this cpu - 300W or more !!
and such a load you will only manage in the benchmark ,.,.in games or your usage --is all for this cpu LOW USAGE ! :D
Pro
Like the others said, it's useless with your CPU. It's slightly above the limit already, at stock!
Also, your DDR4-4000 is losing performance, due to the divider (Gear2 mode) introduced with Rocket Lake above DDR4-3600.
It's faster if you set it to DDR4-3600, because then you can run it in Gear1 mode. Anything above, and the memory controller will run at half the frequency, losing a lot of performance. Same as on AMD.
For all the explanations (OC and RAM) see here: https://forum-en.msi.com/index.php?threads/11900f-memory-overclocking.364100/#post-2065943
And the threads i link to there.
Also see RAM explained: Why two modules are better than four / single- vs. dual-rank / stability testing
Encryptme
Encrypt Everything
I have also been looking all over Reddit and YouTube for answers, when I leave my settings on AUTO with Intel Adaptive Boost my vcore hits 1.6v which I'm not impressed with - I have the same setup as the OP.
M1904
If i remember correctly Thermal Velocity Boost mixed with static voltages for both the SA and core and even a negative offset for both is what helped me. Let me try and dig up the XTU profile real quick.
ajiglesias154b02d0
I don´t know where to leave this OC profile, I am also new to this forum. I have an Intel MSI z590 MPG GAMING PLUS, with a i9 Comet Lake UNLOCKED to as much as 5700. The BIOS came with two XMP. The point is that the first of them resulted in unstability of the system, frecuent hangouts and reboots, etc, as the CPU got rocketed too much. Finally I found a new combination wich resulted in the best perfomance of the system, the CPU remained at 5100, and the patriot vyper memory, which came publicited with as much as 4400 Mhz, (I had 32 GB in four DIMMS sockets with 8 GB each one), at 4100 Mhz. I hope to review the changes (I forget them frecuently, for I use not to share, as the best chefs do, the secrets of my cuisine) and share them here.
Pro
I don't think the validation file is good for anything. If you want to show your OC results, you need to link to your actual validation on https://valid.x86.fr/
Alan J T
Demon God
>>Please read and comply with the Forum Rules.<<
>>Posting Guide<<
Best to start a new topic this one is outdated too much
Status
