D
dermike
Guest
Is there any way to change the settings for the cpu-fan for the mega pc?
I noticed that my p4 2,4 ghz only uses 1,7 ghz... so I checked the heat, and it seems to be very hot in the box. (all temp-apps show different temp though, so not sure how hot exactly.)
Anyway, I found out that the cpu-fan isn't spinning all the time... it only spins up for short whiles when in windows. Works fine when I'm in bios. (where the temp is steadily on 40 degrees c).
So how can I make the fan spin all the time in windows too? It apparently works, but why not all the time?
Thanks for any help!
