B
bickel72
Guest
RE: Firmware v2.00.02 & Driver v1.672 Update dated 06/04/06 for Megaplayer 533 - Model MS5533.
I think that there is a possible problem with the above Driver & Firmware Versions as they do not seem to work for the Mega Player 533 - Model MS5533 ???. It renders the player inoperable (ie.Unable to turn player on at all) and also makes the 256MB flash drive unrecognisable to the computer (ie. computer asks for a disk to be inserted into the flash drive, similarly like the SD Expansion slot)
All Steps to update the firmware were followed to the letter, including no battery, updating to the new version of the driver software v1.672, formatting the drive at the same time and pressing sustained "play" button.
Possible Fix
: I was able to make the player operable again by reinstalling the original driver software & rolling back the firmware version back to v1.00.06 again (Try original firmware v1.00.02 if you haven't saved the v1.00.06 Firmware to your hard drive, as MSI does not have any longer the v1.00.06 firmware on their website to download anymore
). It now works as it did before
(unfortunately still with the "ROCK" setting bug)
NOTE: In order for computer to recognise the drive, Press sustained "Play" button when connecting to the computer, then please go to "start" (below left corner) and enter "programs" and choose "MSI MEGA PLAYER MS-5533" then "Download Firmware".
Computer should then recognise the player and allow for the firmware update :lol_anim:.
My main concern is that many of MSI's other unsuspecting customers will download this particular software and experience the same problems as I did. They probably won't be able to figure out how to rectify this issue & therefore unfortunately be left with a player that does not work at all
I have logged this problem now with MSI, but have yet to hear a response from them.
Has anyone else out there experienced this same problem or is it just me??? ???.
I searched this forum for any similar posts for this problem but found none.
If I am doing anything wrong to update firmware v 2.00.02, please let me know.
I did notice however that driver v1.672 software for MS5533 was called a "Megastick" and NOT a "Mega Player". Is this possibly the cause of the problem as it is the wrong driver for the MSI 533 Mega Player - Model MS5533 ???. Any help with this would be greatly appreciated.
.All Steps to update the firmware were followed to the letter, including no battery, updating to the new version of the driver software v1.672, formatting the drive at the same time and pressing sustained "play" button.
Possible Fix
). It now works as it did before NOTE: In order for computer to recognise the drive, Press sustained "Play" button when connecting to the computer, then please go to "start" (below left corner) and enter "programs" and choose "MSI MEGA PLAYER MS-5533" then "Download Firmware".
.I have logged this problem now with MSI, but have yet to hear a response from them.
..I even unplugged the USB cable during format process just to see what will happen..nothing..after reinstallation it worked again..in all I maybe formated it and reinstalled it for about 25-30 times until I made it to work as it should..at the time I even made it to work with v2 fw but it was showing 000.000.000 version for "Boot Manager" in updater prog. details and I thought that was some kind of bug and it is normal and I used it for a week until i started to mess with it again until I succeded
are BAD / corrupt ... so heres the workaround ...
