talonslas152f02d4
- May 23, 2022
So, I have an MSI X370 Pro Carbon MB and a Ryzen 7 1700x. I've updated the BIOS every time a new release was posted with no issues. However, this time, for some reason, when I boot into the BIOS, select MFlash, it asks to reboot into flash mode, which I do, it reboots, then says entering flash mode, then black screen, and that's it. I also noticed my numlock no longer works, so I'm guessing the PC is crashing. This is the first time I've ever had this happen. I tried several times to no avail. I pulled the CMOS battery for about 10 minutes then put it back. Booted into BIOS, selected MFlash, rebooted into flash mode, black screen. I contacted support, and the genuis there just sent me a link on how to use MFlash to update the BIOS.
Anyone have any ideas on what might be causing this, or possibly a workaround? I was just going to drop in a 5700X and just hold off a couple years before completely redoing my system, but if I can't get this board to flash, might have to consider alternatives. Probably go with a different brand after dealing with MSI support.
Thanks to anyone who has any helpful info.
