Missing 6+2 pin PCIe cables
Hi. I got the msi a750gl psu off amazon but weirdly it was missing the 6+2 PCIe cables (seemed to have too many sata cables instead…). I contacted Amazon/msi and options seem to be:
1. Return entire psu for replacement
2. Amazon will refund 11 quid to get my own cables
3. Wait to see what msi come back with
Any thoughts/suggestions? I have installed the psu on a new system (my first build with help from a friend), albeit running on igpu untill I can get the cables sorted… I.e. preference would be to not have to diss assemble/send back to amazon if I can avoid it but from a search online getting spare cables can be risky if they aren’t specifically compatible with the psu?
Personally I would go with option 1 as something is not Right with it so get it Replaced
[QUOTE="timothy.iron152002d5, post: 2364112, member: 1041302)not sure otherwise how long mai support tend to take to come back? [/QUOTE]
usually 72 hours but can be longer especially as its been the Weekend. also in the UK they do not Handle Issues like that in the UK as its Mainly Laptops that they can do things with.
