Missing serial number stick on 2070 super Ventus OC
Not sure if this is the right place to ask but I recently have been having issues with my GPU, it's been a little wonky since i got it a year and a half ago now but the problems have gone down hill, temps skyrocket no matter how much I play with the fan curve (My case is a 4000D airflow with 3 front 3 side and 1 back 120mm fans and a 360mm AIO on the top so airflow isn't really an issue, I get strange artifacts in many games (have tried many different drivers, underclocking both GPU and memory and nothing has worked, even when my gpu temps are low the artifacting remains) I've tried to reseat the card as well and nothing, have finally decided to just bite the bullet and get an RMA but upon looking at MSI's website of where the serial sticker on the Ventus is located It seems to be missing my serial sticker completely. I bought this as part of a custom build from cyberpower PC directly from them and have proof of purchase, is there anything I can do to still RMA...
Alan J T
See if using MSI Centre can pick up the serial number And as it is a Prebuild you may need to go through Cyber Power
Administrator
Yes, go trough your OEM seller/vendor.
The copy of S/N is also written over the box, but you can't prove that's the same GPU if its missing from the GPU.
