Mistic light
joseph.bc15d402ec
Bonjour,
Quand je vais dans le "Led Style", je choisis le mode désiré et je fais appliquer.
donc par exemple si je choisis "éteint", ça s'éteint.
Au redémarrage de l'ordi, mon choix n'est pas gardé
Y a t-il une solution
merci
bonne journée
Joseph
This is an English forum. Could you please post in English and include the product model in your post? Thank you.
Sorry,
My Question :
When I go to the "Led Style," I choose the desired mode and click apply.
For example, if I choose "off," it turns off the lights
But, When I restart the computer, my choice isn’t saved and the lights of the RAM sticks are still switch on
Is there a solution to keep my choice ?
Thanks in advance
Have a good day,
Joseph
Could you please provide the msi product model name or serial number? Also, if MSI Center is installed, please update the version as well. Thank you.
