Model Codex R 12TC-059US
Costco started carrying this model and I am not able to locate a specification sheet posted at this time. What I am seeking is what motherboard is this product and what is the maximum memory this motherboard supported. Thanks.
badboy2k
OS: Windows 11 Home
CPU: Intel® Core™ i7-12700F 8P+4EC/20T 2.1-4.9 GHz 25MB Cache
Motherboard: MSI B660 ATX Motherboard (Will be a Modified Version of the MSI PRO B660-A DDR4)
Cooler: Air RGB Cooler
GPU: NVIDIA® GeForce RTX™ 3060 12GB GDDR6 192-bit
RAM: 32GB DDR4 (2 x 16GB)
LAN: 1 x RJ45 (2.5GbE) Realtek RTL8125BG
Wireless Communication: WiFi 6 (802.11ax) 2.4Gbps Dual Band 2.4GHz, 5GHz
Audio: 7.1 HD Audio (Realtek AL897)
Video Ports: 1 x HDMI-out (2.1), 3 x DP-out (1.4a)
I/O:
Front:
2 x USB 3.2 Gen1 Type-A
1 x Mic in/ 1x Headphone out
LED Button - Press and Hold 3 seconds for software mode
Rear:
1 x USB 3.2 Gen2 Type-C
1 x USB 3.2 Gen2 Type-A
4 x USB 3.2 Gen1 Type-A
2 x USB 2.0
1 x HDMI-out (2.1)
3 x DP-out (1.4a)
Front:
Rear:
2 x USB 2.0
Storage: 1TB M.2 NVMe SSD + 2TB HDD
Peripherals:
MSI Gaming Mouse
MSI Gaming Keyboard
PSU: 650W 80+ Glold
as its a MSI PRO B660-A DDR4 it would be a max of 128GB so 4x32GB DDR4 Modules.
OS: Windows 11 Home
I/O:
Front:
Rear:
2 x USB 2.0
1 x HDMI-out (2.1)
3 x DP-out (1.4a)
Front:
Rear:
2 x USB 2.0
Peripherals:
MSI Gaming Mouse
MSI Gaming Keyboard
PSU: 650W 80+ Glold
Thank you!
lorenz15ae02e8
OS: Windows 11 Home
I/O:
Front:
Rear:
2 x USB 2.0
1 x HDMI-out (2.1)
3 x DP-out (1.4a)
Front:
Rear:
2 x USB 2.0
Peripherals:
MSI Gaming Mouse
MSI Gaming Keyboard
PSU: 650W 80+ Glold
If I added memory to this would all the modules have to be the same capacity? Since it comes standard from Costco with two 16 GB modules, could I keep those in there and add to 32 GB modules?
badboy2k
Mixing Memory is a Bad Idea even if you got another pair of the same spec Kingston Fury Modules it has as they may have changed the Memory Chips on them and that can lead to severe Issues.
its better to buy a new Kit of memory for it that is 2 Sticks as 2 are better then 4 Modules as it puts way less stress on the Memory Controller so will actually run at there XMP Speeds. with 4 it usually will run at least 30% slower as you will have to drop the Frequency to even get them to run.
