Modern14281 (Modern 14 Inch, i3intel) Hinge Problem?
marconc3154502de
So I've had this laptop for about half a year as of 2/22/21 and I had no problems until recently my hinge started to just break itself???... The screw that's supposed to hold the back right side came off and I'm pretty sure I cannot put it back in because the plastic that was inside also broke when I tried to put it back in. I did not use the laptop with excessive force when I was working on putting the screw back nor when I was using it on the regular. Keep in mind this laptop top was brand new and I had just gotten it as when they were delivering it to the store I bought it from. I want to know if it is only me or others had problems in the right hinge. If anyone else has a problem with other laptops' hinges, how much do you possibly think it is to repair in US $.
Crazydonkey
SECOND LIEUTENANT
Do your laptop still under warranty?
I suggest sending back the unit to service center, maybe the repair will be covered by warranty.
