Monitor arm adaptors
davidgarland1
Hi all, just wondering if anyone could point me in the right direction for the VESA adaptors I would need to attach a MSI Optix G27C4 and a MSI AG321CQR to a set of dual monitor arms?
Thanks.
MSI Optix G27C4 is a 100mm by 100mm Vesa Mount and the MSI AG321CQR is a 75mm by 75mm Vesa Mount!
usually the Monitor itself comes with a set of Standoffs to mount the screen to the mount.
Usually, but not always. My first MSI monitor didn't come with standoffs but the second did.
On the other hand, the monitor bracket I bought for wall mounting did come with the standoffs :)
Thanks for the replies. Unfortunately no standoffs came with either monitor so I’ll need to purchase some. Would anyone happen to know if I will need to buy MSI standoffs or will a generic version work?
I just used half a dozen washers that were sized properly for the screws I was using.....worked well enough once tightened down. ;)
Cheap way to do it, but not necessarily 'easy' by any means. But it worked!
That's exactly what I did the first time :)
These tend to be "universal" standoffs, though thread size may be different on both monitor and the arm.
