Monitor brightness dimming
btfgamer157802da
Just bought the Artemys 32" monitor and love it...the only issue is every 20 minutes or so the brightness will lower noticeably. I turned off power savings in Win 10, but it still happens.
Any ideas where the problem might be?
Thanks.
badboy2k
Thanks.
do you have HDR enabled in windows if you do that tends to do that alot?
GWraith
The bug hunter!
Yes HDR causes this. Install Gaming OSD if you can and shut it off, you need the extra USB cable. If you cant through that app then you will need to go into the monitor settings and shut it off on the monitor.
