Monitor Matching MSI Creator M16
Hello!
I've been looking around MSI's monitor to get a multimonitor setup for my Creator M16 for video editing and drawing. After looking at specs and looking into what specs mean what, I'm still a litle confused.
Just wanted some suggestions, size doesn't particularly matter as long as it's above 16 inches. Thank you!
You can choose any monitor you like, depends on the display type(Mini LED, OLED...), the size, and more.
This is the forum for laptops, you should make sure that the laptop equipped with two or more external display ports and how you are going to connect them.
Refer to the external display info: https://www.msi.com/faq/faq-1661
If you would like to get some suggestions regarding the external monitor, you may try to post on https://forum-en.msi.com/index.php?forums/gaming-desktop-pcs-monitor-all-in-one-pcs.101/
Thank you!
