Motherboard changed my SPD. Failure my DDR5
dsamjjlen152f02d7
I have two DDR5 T-Create Expert 96GB (2x48GB) 6800MHz modules and a MEG Z790 ACE motherboard.
As a result, the SPD information on one of the memory modules got erased (possibly due to RGB issues), and consequently its XMP profiles no longer work (the single module now runs at a maximum of 5800MHz). I’m trying to figure out how to read the SPD data from one module and rewrite it onto the other. But so far, I haven’t found any working solutions (without specialized equipment).
Unfortunately, I also don’t have the option to send the memory back to the manufacturer.
Has anyone encountered a similar problem and managed to solve it? I’d be grateful for any information.
Hello, what is the full name of the memory and the name of the company?
Hello! Team Group
T-CREATE EXPERT DDR5 DESKTOP MEMORY BLACK 96GB(2x48GB) 6800MHz CL36
CTCED596G6800HC36DDC0​
Hello, this RAM is not compatible with the motherboard, so the speed is lower and there is no RGB in it. If you can return this RAM, I will direct you to other, better RAM.
F5-6400J3239F48GX2-TZ5RK​
I have put you compatible RAM + RGB and it is very excellent
Thanks, but it's working. Everything was fine before that. And at the moment, one module works well on xmp without errors. I checked and in fact the SPD information was changed on the second module, completely incorrect. Therefore, it's only about SPD here, unfortunately, and I'm looking for ways to return it as before
If you want to buy in the future, I advise you, if you have a limited budget, to buy this RAM for only $200.
F5-7200J3646F24GX2-TZ5RK​
Very powerful and wonderful RAM. I advise you to try it.
G.SKILL Trident Z5 RGB Series (Intel XMP 3.0) DDR5 RAM 48GB (2x24GB) 7200MT/s CL36-46-46-115 1.35V Desktop Computer Memory UDIMM - Matte Black (F5-7200J3646F24GX2-TZ5RK)​
Instead of buying advice, it would be better to try to help with the issue at hand.
The only way i know that might enable you to write to an SPD is Thaiphoon Burner, it has to be run as admin. Don't worry if your browser warns about Thaiphoon Burner, see here. First you can click on the "Read" icon and read the SPD information for each module, then "File" - "Take a screenshot". I'd like to see the current state.
I tried using Thaiphoon Burner, but the developer, as far as I understand, stopped supporting the program. And in the free version, it is impossible to fully do everything. It seems to me that I have already tried many options and have not yet found a solution. I don't see any point in buying new modules yet
Вместо того чтобы покупать советы, лучше попытаться помочь решить существующую проблему.
Единственный известный мне способ, который может позволить вам записывать в SPD, — это Thaiphoon Burner , его нужно запускать от имени администратора. Не волнуйтесь, если ваш браузер предупреждает о Thaiphoon Burner, см. здесь . Сначала вы можете нажать на значок «Читать» и прочитать информацию SPD для каждого модуля, затем «Файл» — «Сделать снимок экрана». Я бы хотел увидеть текущее состояние.
Hmm, everything looks ok, only one of them doesn't have XMP profiles, like you said. I would say, leave XMP disabled and check out the "Memory Try It!" profiles in the BIOS. See if you can get something to work that's around the XMP speed.
Yes, I've already tried it. When manually configured, the second module refuses to start with the settings and starts only from 5800. All because of a faulty SPD. I need to somehow get the firmware back on the module.
This tool is the only way i know how to write to the SPD (for mere mortals). You can try to reach the author under support@softnology.biz, he's known as Vitaliy Jungle, see if he can help you out somehow, tell you how to buy a Pro version or whatever. But it seems he has vanished from the face of the planet more or less.
Этот инструмент — единственный известный мне способ написать в СПД (для простых смертных). Вы можете попробовать связаться с автором по адресу support@softnology.biz , он известен как Виталий Джангл, посмотрите, сможет ли он вам как-то помочь, рассказать, как купить Pro-версию или что-то в этом роде. Но, похоже, он более или менее исчез с лица планеты.
Thanks! I will try
