I bought this motherboard as part of my first build. I was able to install the OS and boot into Windows. However, I started having problems grabbing updates. I had 2 SSDs installed. After discussing the issue with other more well-versed people, I was informed that this is an issue with Windows where the updates are spread across both SSDs but the OS thinks it's only on one. It was recommended that I do a fresh install and grab the core updates with only 1 drive installed then add the other one back in later. Using Win 10 Settings menu I reset the PC, but when it restarted it didn't boot and after some time even the fans on the GPU stopped spinning. I tried powering off and rebooting but nothing happened. I tried resetting the CMOS using a screwdriver to bridge the jumper pins but that has had no effect. Checking the EZ Debug LEDs on power up showed that the CPU LED was red, the DRAM LED was white and the VGA LED was white. The BOOT led wasn't lit which I take to mean that it can see my setup tool which I had on an external drive plugged in. I've re-seated the RAM, the GPU and the CPU including the cooler and now only the CPU led (still red) and the VGA LED turns on when I try to boot.. I've checked the GPU and the locking clip is engaged and I can't push it in any further so I think I've connected it correctly. When I re-seated the CPU, I checked and couldn't spot any bent or damaged pins.
The attached file is a text file of the system configuration.
I did try and set this up as a support ticket, but the website doesn't do anything. It just refreshes clearing some of the fields and doesn't actually create a support ticket.
