Motherboard not showing in Mystic Light
alexhb280159102df
I have a MSI mag Tomahawk B650 wifi motherboard that is not showing up in mystic lighting. The only thing showing is the ram and I can change the colours on that.
How can I add motherboard to one of the profiles to change the fan colours.
Any help appreciated.
I also found out today that the motherboard from mystic light is missing. Motherboard : Z790 Tomahawk
also i have corsair ram and in mystic light it also missing. I installed drivers and it's still missing
Have a Z590 Gaming Carbon wifi Motherboard, was working perfectly this morning. Switched on the pc this evening and Motherboard remained at a static green colour while my MSI 3060TI remained with rainbow colours so colours not synced. Loaded up MSI centre and it started installing an update, after which the motherboard is no longer detected by mystic light but the GPU is.
Tried multiple installs and uninstalls but it just will not work.
This is driving my OCD mad as I usually keep everything on CPU temperature, green, blue, purple and red.
Really hoping we can get a solution for this.
Just bought an MSI mouse(GM20ELITE), before i had no issue and the motherboard showed up. Unfortunately, when i plugged in the mouse my Motherboard disappeared with the new update. Very unsatisfying.
Just for reference, my motherboard is an MPG X570S EDGE MAX WIFI.
It's fixed now. Connect the PC to the network, then reboot the computer to refresh the Mystic Light.
It should works, try reboot your router and PC.
If still the same, try again a bit later.
Just got mine to work again. Unfortunately it didn't work earlier even though I was connected to the Internet so I completely uninstalled MSI center and the sdk, rebooted and reinstalled for the hundredth time. I then rebooted the pc and noticed my motherboard and case fans where now rainbow colours not static green, loaded up Mystic Light and behold everything back to normal.
Hope this helps anyone who like me earlier still found it not working.
