Mouse MSI Clutch GM41 Wireless firmware update problems
jordi riu Popito
Zwift Tezh Attacus
El mismo problema, tengo el nuevo ratón MSI Clutch GM41 y me pide una y otra vez que actualice el firmware y no puedo modificar las teclas del ratón
vvnighi12b502b0
im having the same issue , i tried installing dragon center and MSI center but both are stuck in update loop
mbushnaq
I had to return the mouse because it will never update whatever I try to do. It seems there were a batch of mice that have the firmware stuck at a certain version. I bought another one from another reseller which had a newer firmware, and I was able to update successfully without any issues.
Hi - had the same issue - try doing Live Scan (Advanced) and update the firmware there. Mouse is now recognised in ML in both wired and wireless settings
Hello, I just bought the same GM 41 wireless mouse and I have the same problem with both MSI Center and Dragon Center that cause the firmware update to go into a loop. What can I do?
I tried both with cable and without cable on the mouse, but nothing .. It tells me that the update has been done, but every time I come back it tells me to do it again!
Firewall and antivirus have been disabled!
