ms155e02e2
- Feb 2, 2026
A few annoying/broken things I have found with the MPG 274URDFW, would be nice to get them fixed, or see if anyone else gets them.
Firmware version 026
1) When I have the monitor plugged in by USB (old style) so I can use it's KVM functionality, it results in a new read only disk "MSI Gaming Series" being added to my computer. This randomly breaks windows explorer (start menu disappearing, file exporer freezing etc) which is solved by switching the kvm from upstream to USB-C. You can watch everything fix itself as soon as you change the option!
2) The menu/OSD doesn't work when changing inputs. If you select the wrong one, you have to wait ages for it to time out to switch it back.
3) If you enable USB-C power delivery, and use it as the display input, it will stop working when the device is fully charged (Dell laptop). You therefore can't use that setting and have to charge the laptop with a seperate cable
4) No idea what the KVM auto mode does? I was hoping that it would switch the KVM to USB-C when that was used as input, and upstream for the others, but as far as I can tell, it doesn't do anything?
