lore215cf02eb
- May 21, 2026
Hi everyone,
I recently purchased an MSI MPG 341CQR QD-OLED X36 monitor. While I am absolutely loving the image quality, I am running into a few issues with its additional features, which are making the overall experience less than smooth.
Specifically:
1) AI Care Sensor (in Monitor Mode): the sensor only seems to detect my presence if I stay within a maximum of 50 cm from the screen. If I simply lean back in my chair, moving to a distance of around 70 cm - which is a perfectly natural viewing distance for a monitor of this size - the screen shuts off. This happens even in a well-lit room. Needless to say, this feature is almost unusable like this. Is my unit/sensor defective, or is this its "normal" behavior? Is this something that could potentially be fixed in a future firmware update?
2) Built-in USB Hub: I turned "Type C PD Charge" ON so that the monitor USB ports stay powered on even when the monitor goes into standby. However, all USB ports still get shut off and then back on when the monitor wakes up from an inactivity standby. This is particularly annoying because I have my mouse and keyboard connected to the monitor for the KVM functionality, causing me to temporarily lose control of them every time the screen wakes up. Is there any way to prevent this power cycling from happening? Interestingly, I noticed it doesn't happen when the monitor wakes up after being turned off by the AI Care Sensor. Again, assuming there's no current workaround, is a fix via a future firmware update likely?
Thanks in advance for any insights or suggestions!
Specifically:
