MPG 341CQR QD-OLED X36 - Burning in after 3 days ?!
Goga Andrei
Hello everyone,
I've owned my MSI MPG 341CQPX (X36) QD-OLED for only 3 days and today I experienced a strange issue that has me a bit worried about the long-term health of the panel.
While playing Escape from Tarkov, I initially thought the visual artifacts were caused by the game itself. However, within approximately 5 minutes the issue became progressively worse and more noticeable. The screen started showing large horizontal bands/artifacts across most of the display, similar to what can be seen in the attached photo.
At that point, I turned the monitor off and left it powered down for about 10 minutes. After turning it back on, I manually ran the Panel Care process three consecutive times. Following the third Panel Care cycle, the issue completely disappeared and the monitor returned to normal operation.
What concerns me is that the monitor is only a few days old and I have been extremely careful with OLED protection features from day one:
  • The monitor firmware was updated to the latest available version on the first day of ownership.
  • I always allow Panel Care to run whenever the monitor requests it.
  • Pixel Shift is enabled and set to Fast.
  • All OLED Care and burn-in protection features are enabled.
  • Static Image Detection is set to the highest protection level.
  • Logo Detection is enabled.
  • Taskbar Detection is enabled.
  • Dimming protection settings are enabled and configured for maximum protection.
  • I have not disabled any OLED protection features.
Because the issue disappeared after turning the monitor off and running Panel Care three times, I am unsure whether this was:
  • Temporary image retention
  • A Panel Care compensation issue
  • Firmware-related behavior
  • A signal/cable issue
  • Or a potential panel defect
Has anyone else experienced something similar on this monitor or other MSI QD-OLED models?
I would appreciate any feedback, especially from users who have owned the monitor for a longer period of time. Since the monitor is only 3 days old, I would like to know whether this is considered normal behavior or if it could indicate a future hardware problem.
I also did a ticket at service and waiting for a answear
Thank you.
Hey! Did you get any update or fix this issue? I'm having the same problem
Yes, i sented it to RMA and i asked for a new monitor because I didn’t wanted a monitor wich came from Netherland to Germany and to Germany to Poland and 2x times in same UPS depo to be “fixed” and then to came back again to Germany and i was afraid of any transport damages wich its hard to proof it. Of course they didn’t gived a new one so I was in still the 14 days of order so I cancel it and I was going to Alienware, the customer service from them it’s 100000x more better than MSI wich is giving only short answers and answers like a robot it’s answering just to “skip” it. At Alienware I saw many people wich had problem and got a RMA and they directly get a replacement without to wait until it was fixed. So this was my last thing wich I buyed from MSI, too bad because in the first days I was really happy with it but when I saw all this things happened, they let me with a bad taste. Try to get your money back and don’t go anymore MSI because on different topics/forums they sayd it’s like lottery with them.
Thanks for replying. That sucks :( I really liked this monitor and only had it for a couple of days. Might switch too in that case to a different monitor
Believe it or not, mine died too, although it happened after playing Tarkov. I owned it for a two days and these lines appeared after AI Care switched monitor off and on. I'll be returning it as well, but through my local retailer.
Those lines appear to me every 2 cycles of panel protect; if you keep doing panel protect, at some point they disappear completely. Last time it took me about 20 to 25 minutes doing panel protect cycles until the lines went away, and from then on I decided not to do it anymore.
I don't think it's a general problem with the panel, but rather that panel protect + vstripe are causing some kind of error
