Here is an issue I found with FW.018 KVM management:
Device A: PC through DP and USB-B
Device B: Macbook through USB-C
Both being set through OS to turn of display after x minutes. When working on device A, KVM sticks to device A, as expected. In the background, Device B turns off it's display signal due to inactivity (but does not sleep). When switching to Device B, we get a no signal, expected, but the KVM sticks to forwarding inputs to Device A, so there's no way to wake Device B from the KVM connected peripherals.
FIX: MSI, please do a firmware update where the KVM forwards to the selected device based on display input source no matter if the adjacent display signal is there or not.
If I manually switch to a display input through either the OSD or through DDC via keyboard shortcut script set on both mac and PC, It's obvious I want my keyboard and mouse to go to said device, no matter if the screen of that device is on or off. I have been waking up my devices via SSH scripts but this is a workaround and not a neat solution.
