mrjames298156f02df
- Feb 7, 2026
I bought this monitor a few days ago, it has reached 24 hours of use and has prompted me to do a panel protect.
The issue is that once done the monitor after a minute asks me to do it again and I am stuck in this loop, the app gaming intelligence from msi had a pop up after the protect to tell me the panel was refreshed but it still prompted me to do another about one minute after.
Things I have tried,
Made sure windows is not turning off the monitor or putting it to sleep, to further make sure, I disconnected the pc and only had the monitor with power but the same outcome was had.
I did a full protect and left it for 10 minutes before turning back on, I unplugged the monitor for 15 minutes and tried again but no luck.
I let it do it in stand by, auto and then initiated it manually.
I downloaded gaming intelligence and let it run through the app popup .
I turned off all power saving, ultra low power mode and all oled care features but no luck.
I downloaded the monitor driver on the monitors support page but no issue, I installed this through device manager.
Outside of this the monitor works flawlessly without issue but since it has hit 24 hours I cannot continue to use the monitor as it forces it in to panel protect .
