MPG B550 GAMING PLUS - PROBLEM WITH USB
brunobarre15bd02e8
Good morning friends
I have an "MPG B550 GAMING PLUS" but I'm having difficulty leaving the USB ports connected when the computer is off, as I need to charge the mouse and headset.
Where do I find this option in the bios? I've looked through it all and haven't found any related options...
Thanks
Check in Advanced view in the BIOS (press F7) under Settings\Advanced\Power Management, if you can enable USB Standby Power.
Otherwise, check here if "Resume by USB device" can do the trick:
No, i think this first option may only be found on the Intel MSI boards, not the AM4 ones. So you need to check if the second option does what you want, because that one you should have.
Thank you so much, man. I couldn’t find the first option, but just like you said, the second one — Wake Up by USB device — actually worked. Thanks a lot, you really helped me, I would probably have given up thinking it wasn’t possible.
