MPG b760i edge wifi BIOS update killed audio
halfful15df02e8
I just updated my BIOS to the latest 7D40vAD, and audio quit working. The Realtek driver no longer appears in the Win11 sound control panels. It's not visible in the Device Manager unless you "Show Hidden Items" and in that case the OS lists it as an unconnected device. There are tons of threads about this problem, here and on Reddit, but no apparent resolution.
I've already tried,
- reinstalling the Realtek drivers
- downgrading the bios back to AC
- disabling/enabling the audio engine in the bios
- CMOS reset via the mobo jumper
What's the next move here?
I also tried reverting to the earliest BIOS rev with 0x129 microcode, which is AA, but that also doesn't work.
Other threads, like this one for the B660 https://forum-en.msi.com/index.php?threads/realtek-audio-not-working-after-bios-update.390883/ report that audio works again after a version downgrade, but I don't want to go all the way back to something with Intel microcode bugs.
I also tried the Realtek Audio Control app, per this thread , but it won't install due to a missing driver (presumably because the audio device is not enabled).
Only need to go back for a few minutes, all up
See DM Once it is patched, it shouold stay that way when you flash to the latest BIOS from the supplied Bios
Rolled back to A81. Audio worked. Then updated to the latest AD again - unfortunately no joy. Is it worth trying updates in release sequence A81, A9, AA, ... without any big jumps?
It's actually A9 that breaks the audio, so proceeding incrementally from 8 to D isn't really an option anyway.
Finding the actual working RMA page link is quite challenging. Franz Kafka must have had an MSI mobo.
Go to your Member Center, on the left hand side you will see "Apply for Service". Just use that link.
Glad you pointed that out. The RMA form generated by the web site does not include the address (or else there's a format problem with the page code that prevents printing it). But their email confirmation does include it.
Thanks for the advice everyone!
Sent it in for service. Service tracking was reassuring - I knew when it arrived and left. Got it back last week, but didn't have a chance to rebuild and test until today. No intel on the packing slip - it just says "Repair OK".
Sadly, nothing changed. They updated the BIOS (I had left it on v9 I think) to the latest - but the audio is still borked. I tried downloading the Realtek drivers and cycling the HD audio control in the BIOS, but no luck.
As the saying goes, "insanity is doing the same thing over and over and expecting a different result," so I probably don't have the stomach for another RMA. I'll either demote this to dumb server or dump it on ebay.
:( sorry to hear.
Maybe just get a cheap audio card, either USB or PCIe? I personally wouldn't know if a BIOS killed the audio chip as I use dedicated card myself.
Yes - I'm kind of regretting spending the money and time on the RMA. Other threads indicated that it would not be fixed. For twenty bucks I could have gotten a USB 3.5mm adapter and saved tearing down and rebuilding the machine.
