MPG CoreLiquid K360 pump noise
h_bardak
Hi.
I've recently purchased this AIO and everything looked nice at first. But the pump noise is killing me. I can't stand it.
I've correctly installed this AIO (side mounted radiator with tubes at the bottom, lian li o11 case, pump is slightly above the mid line of the raditor).
Pump runs at 1750 rpm on silent mode which makes this irritating high pitched sound more obvious than at 2000 rpm. 2000 rpm is the sweetspot for this noise (but still unacceptable). Unfortunately MSI Center won't allow us to go under 60% (2000 rpm) for pump fan on custom settings.
I've read plenty of this issues so I guess K360s are bad about pump noise. Shoud I RMA this AIO?
h_bardak
It seems that I can adjust fan settings in BIOS but whatever changes I make, pump/fan speed won't change. It is stuck at 2750 rpm in BIOS.
