MPG CORELIQUID P13 & MSI Center issue
miklolivie12e402b3
Hello everyone,
I just received my CORELIQUID P13 and assembled it. It made a lot of gurgling noise at first, then it normalized, and now it's very quiet.
However, I'm having an issue with MSI Center and the LCD display. The changes I request to the display simply don't apply on the fly; I have to restart the PC for them to take effect, which is absurd and clearly not normal behavior. I can't play a YouTube video, and in the "Hardware Monitor" settings, it offers me everything EXCEPT the CPU specifications, which are precisely the ones I wanted to display (I only have GPU (Temp, Freq & Usage), Memory (Usage), and More (Framerate)).
The AIO block is properly connected everywhere (CPU_FAN, AIO_PUMP, ARGB, and USB to an appropriate port on the motherboard), the informations it collects are accurate (date, GPU or memory specifications, etc.), the requested settings are indeed modified at the next startup, but it should be possible to do this on the fly, and above all, why don't I have the CPU data?!?
Ah, and I also now have a permanent window in my Windows applications, which shows the LCD screen display, and which I don't have much to do with, since I ALREADY have this display on the AIO block oO And besides, in any case, we can't access it if we click on it... I also specify that the changes I request in MSI Center do not apply in this window either.
I uninstalled/reinstalled MSI Center, it's up to date, the AIO block is correctly detected, etc. I don't understand what's going on. Please help me, thanks a lot by advance.
Setup (just in case) : ASUS RROG STRIX B860+F Gaming Wifi, Intel Core Ultra i7 265K, 64GB RAM G.Skill Trident Z5, Samsung 990 Pro and 990 EVO Plus m.2 SSDs, MSI 5070Ti Gaming Trio OC, AsRock Steel Legend SL-850GW 850W. I also have dual monitor.
Merhaba, sorun çözüldü mü? MSI, oyuna girerken oyunun ekranı tanımaması sorununu düzeltti mi? Buna göre bu soğutucuya geçmek istiyorum.
Hi, has the problem been solved? Did MSI fix the issue of the game not recognizing the screen when entering the game? I want to switch to this cooler accordingly.
Hello, I'm using an MSI Mog P13 liquid cooler and I was very happy with it, it had no problems. However, for some reason, when I install the latest version of the Nvidia driver, the screen freezes. Can you help me? I completely uninstalled and reinstalled MSI Center, but it didn't help. Maybe there's a solution.
You mean P13 display completely freezes after you update Nvidia driver? Try unplug and replug the USB connector.
By the way, when screen freezes, what does it display? Desktop?
I can't configure the settings. I've unplugged and replugged all the connections, but it's stuck on "please wait." It was working perfectly before, but this started happening after installing the Nvidia driver.
The issue been duplicated and already fixed.
To fix it: Please Remove EZ display and reinstall it again.
Note:
The installing time might take around 30 second
(means the screen will show Downloading, please wait message after he finishes installing EZ display and hit EZ display button),
please wait patiently and it should open the feature properly.
Note:
The problem still hasn't been resolved. Since I bought the P13, I can't play a single game without disabling it in Device Manager. The problem is that when I launch a game, the window constantly minimizes, and I can't find a way to fix it! MSI support hasn't offered any solutions yet. It's incredibly annoying!
Yep it is buggy , when i start my pc its only show cpu temp , have to go in msi center to change settings ( gpu temp etc ) everytime , but for me the bigger problem ist , like mehdi says , MSI ViewXpander Service (32Bit) ist runnig in Backround using 3 to 7 % cpu usage and my cpu ( 5700x3d) running in idle over 4000mhz , when i close this task its come down to normal but the screen is not refreshing , i hope they fix it.... fast
I can put the task in eco mode , and the high mhz usage is back to normal , display is working normal , but i has to aplied every restart ....
Hello everyone,
Hello there, any updates? Did u fix it? I am still in trouble
FYI, guys, I've been dealing with MSI support for over a month now, and I think I've had enough. See our last correspondence:
Me:
Gents,
I've been waiting for a fix for over two months, just like other users... Furthermore, after the software update, frames started appearing on my AIO's screen! I'd appreciate your prompt assistance.
MSI support:
Content:
Sorry for any inconvenience caused, about the issues when you play game, we have reflected to the relevant department, they are checking it, we will reply you again.
About the change in the display of local videos, we have confirmed with the relevant departments that it's because we changed the player after the firmware update. It's not displaying full-screen on the LCD screen, which is normal. Playing YouTube videos is done via webpage playback and will not show this change.
Me:
Gents,
"we have confirmed with the relevant departments that it's because we changed the player after the firmware update. It's not displaying full-screen on the LCD screen, which is normal"
No, this isn't normal. It looks weird and incorrect. You need to fix this ASAP because I'm not going to play just YouTube videos on it. Furthermore, there are long ads before and between YouTube videos, which is annoying and which you can`t skip. I've also created a lot of short custom MP4 files, which are replacing GIF animations. GIF animations aren't supported on this AIO either, which has come as a big surprise to many users. Please pass this on to your departments so they can fix the screen bezel issue. Saying this is normal is incorrect! Especially considering I've seen everything work correctly in full-screen mode!!!
p.s.
I only know one thing: if I work the same way as they do, I will be fired less than a day after starting work!!!
i think they fix the cpu usage , after i start my pc there where random black windows on my desktop , and my cpu temp is now at idle 34c before 42c , but i have to select my infos i want to show every restart only starts with cpu temp
so 3 new version from EZ Display now version 1,0,0,17 , everytime i do a complett new Instalation with cleaner master tool , yet no savings from my settings i choose, every new start its only display cpu temp , nothing more , everyone else suffer from this and fix it ?
