MPG CORELIQUID P13 & MSI Center issue
miklolivie12e402b3
Hello everyone,
I just received my CORELIQUID P13 and assembled it. It made a lot of gurgling noise at first, then it normalized, and now it's very quiet.
However, I'm having an issue with MSI Center and the LCD display. The changes I request to the display simply don't apply on the fly; I have to restart the PC for them to take effect, which is absurd and clearly not normal behavior. I can't play a YouTube video, and in the "Hardware Monitor" settings, it offers me everything EXCEPT the CPU specifications, which are precisely the ones I wanted to display (I only have GPU (Temp, Freq & Usage), Memory (Usage), and More (Framerate)).
The AIO block is properly connected everywhere (CPU_FAN, AIO_PUMP, ARGB, and USB to an appropriate port on the motherboard), the informations it collects are accurate (date, GPU or memory specifications, etc.), the requested settings are indeed modified at the next startup, but it should be possible to do this on the fly, and above all, why don't I have the CPU data?!?
Ah, and I also now have a permanent window in my Windows applications, which shows the LCD screen display, and which I don't have much to do with, since I ALREADY have this display on the AIO block oO And besides, in any case, we can't access it if we click on it... I also specify that the changes I request in MSI Center do not apply in this window either.
I uninstalled/reinstalled MSI Center, it's up to date, the AIO block is correctly detected, etc. I don't understand what's going on. Please help me, thanks a lot by advance.
Setup (just in case) : ASUS RROG STRIX B860+F Gaming Wifi, Intel Core Ultra i7 265K, 64GB RAM G.Skill Trident Z5, Samsung 990 Pro and 990 EVO Plus m.2 SSDs, MSI 5070Ti Gaming Trio OC, AsRock Steel Legend SL-850GW 850W. I also have dual monitor.
I'm experiencing all the same problems you mentioned. It prevents me from going full screen while playing the game, a small window appears when I turn the main monitor off and on, and I can't go outside that window, and it doesn't show any temperature on the screen. I unplugged the USB and started using it without a monitor. Will unplugging the USB cause any problems with its functionality?
