MPG Coreliquid P13 Problem after updating the firmware + EZ Display MSI center bug
I recently purchased and installed the MSI MPG CoreLiquid P13 360. Initially, everything seemed to be working, except for a major issue:
when launching games in full-screen mode, the AIO LCD screen would display my Windows desktop and my game would minimize after about one second.
While looking for a fix, I found that there was a firmware update available for the P13, so I updated the firmware and installed the latest version of MSI Center along with EZ Display. After that, the issue appeared to be resolved — however, new problems started to occur.
Sometimes the LCD randomly shows my desktop icons, and on every cold boot the AIO gets stuck in an infinite MSI logo loop.
More importantly, after installing MSI Center, my CPU (Ryzen 9 9950X3D) was constantly running at very high frequency even while completely idle, causing abnormally high idle temperatures.
I spent a lot of time troubleshooting (BIOS tuning, uninstalling software, etc.), and the only thing that finally fixed the high idle clocks and temperatures was completely uninstalling MSI Center and rebooting the system. After doing this, my CPU behavior returned to normal.
However, I am now left with another issue:
on every boot, the AIO LCD is stuck in an infinite logo loop until I manually go into Device Manager and disable the AicUSBDevice to fully shut it down. I currently have to do this every single time I start my PC.
This situation is extremely frustrating, especially considering the product is marketed as a premium solution. At the moment, I am experiencing instability, broken software behavior, and major CPU side effects just to make the LCD function correctly.
System Specifications:
• Motherboard: MSI MAG X870E TOMAHAWK MAX WIFI PZ
• CPU: AMD Ryzen 9 9950X3D
• GPU: RTX 5070 Ti
• RAM: 32 GB
• AIO Cooler: MSI MPG CoreLiquid P13 360
• GPU: RTX 5070 Ti
• RAM: 32 GB
Salam Mehdi, did you find any solution? From my side i can add - i see FPS drops in games when AIOs screen is working... What a joke....
1 month later . i tried everything , fresh windows , dozen settings , etc msi center and ez display is not saveing setting, i have to redo every start up ... backround is the only thing that is saving.
its start with only cpu temp and my chosen backround , gpu temp fan speed everything else is checkt out after restart , anyone else have same proplem or a solution ? please help ...
Nope - I still see a drop in fps in games when the AIOs monitor is turned on.
