MPG EZ120 ARGB SHOWING AS A REMOVABLE USB (HUB)
Does anyone have a similar issue? I bought this device a couple of weeks ago and connected the fans to the hub included in the 3-fan pack. The lights and speed work correctly, and Mystic Light can manage them. However, the USB is always showing as a removable device, which doesn’t make sense—you wouldn’t want to remove an internal USB device. Any ideas?
All internal USB devices show this (and have done for decades), it's part of trouble shooting etc.
you would have to make it a non Electable device to do that go into Disk Management and find the drive there as it will have some flash memory that is Ejectable which is what its seeing.
go to its Properties
Turn off Quick Removal
that should make it Non Ejectable
