Valethar
- Oct 3, 2021
Greetings,
I've just about finished a new build, and can't seem to figure out why the K360 isn't spinning up the pump or the CPU fan under the LCD. The radiator fans are turning, but all three report as 0 rpm in the MSI center.
No amount of tinkering with the fan curves in MSI Center does anything to engage the pump/fan. I've turned off fast boot in the BIOS, and even set all of the fan headers to max rpm, with zero change.
I can change the RGB on the radiator fans just fine (though the LCD never remembers any settings I give it and I have to manually change it after every single boot, but that's a separate issue...) but forget about altering any speeds on this thing.
It's currently plugged into the CPU Fan 1 header on the board. There is the separate pump header I can switch to if needed. The connector for the AIO was labeled for the CPU fan, so that's where it went for now.
Updating the BIOS from 1.04 to 1.07 changed nothing. Still no movement on the pump/fan. Next step is to try the pump header and the second CPU fan header to see if anything happens there.
Does anyone have any idea what I may be doing wrong here? It's literally my first shot at water, so I could have easily borked something somewhere.
System thus far:
CPU: i9-10900K
MOBO: EVGA Z590 FTW Wifi
RAM: G.SKILL Trident Z Royal 64 GB
AIO: MSI MPG Coreliquid K360
GPU: EVGA RTX 3090 FTW Ultra Gaming
PSU: Thermaltake PF1 ARGB 1050 Platinum
SSD 1: Samsung 970 EVO Plus 500 GB NVMe (Boot)
SSD 2: Samsung 970 EVO Plus 2 TB NVMe (Data)
OS: Win 10 Pro 64
System idles at around 90-100c, so it's utterly useless until I can get those pumps/fans running. I appreciate any insight you can provide.
Thanks!
System thus far:
CPU: i9-10900K
OS: Win 10 Pro 64
Thanks!
