MPG X570 Gaming Edge Wi-Fi XMP instability issues
Hi everyone,
i recently got a Ryzen7 PC build, but i'm unable to have a stable system when A-XMP is enabled, without A-XMP i can run 8 passes or more of memtest without any issues, here are my full specs
PSU: Corsair HX850I
Motherboard: MSI MPG X570 Gaming Edge Wi-Fi
CPU: AMD Ryzen 7 3700X
RAM: G.Skill F4-3200C16D-32GTZR (DDR4-3200 16GBx2, CL16-18-18-38 1.35v), installed to DIMMA2 and DIMMB2 according to MB manual.
BIOS: 7C37v1G
When i enable XMP, i got BSOD's and memtest reports a lot of errors.
Do you have any advice to help me getting my XMP profile working ?
Thanks in advance,
Can you try one BIOS version prior, 7C37v1F? I've heard that there might be problems with the latest AGESA microcode for some people. Not entirely sure it's the case here, but worth a try.
i recommend you restore BIOS default settings for better instability and flash 7C37v1F, the one with AGESA code 1203? do you have stability issues with previous BIOS versions?
Hi, when I got the PC, I updated the bios without checking actual version which is my mistake, however the XMP has never been enabled on this build. I'll try with 7C37v1F thanks
i would update the BIOS to the latest version when i get a new motherboard as well :ROFLMAO:
but like citay said, there seem to be some stability concerns with the latest BIOS.
Yes, Win11 is fully supported after doing this: https://www.msi.com/blog/How-to-Enable-TPM-on-MSI-Motherboards-Featuring-TPM-2-0
It's surprising that the newest BIOS tends to cause these problems, especially with your RAM, because it's a pretty popular kit and not too challenging either at "only" DDR4-3200 with those timings.
But yeah, that first instinct was obviously correct. The latest BIOS with AGESA / ComboAm4v2PI 1.2.0.5 can be problematic when it comes to the RAM. Let's hope AMD or MSI fix these problems soon.
There was a change in the Micro code for the CPU in 1.2.0.5 first one in a while for several of the chips
Yep, there is now word in the tech news about AGESA 1.2.0.5 being problematic. Translation:
"AMD's AGESA ComboAM4v2 1.2.0.5, the latest "stable" firmware for processors and APUs of the Athlon and Ryzen product families as well as mainboards of the AM4 platform, should be installed with caution for the time being. While overclocking in particular is suffering according to reports on Reddit and forums, the next AGESA is already ready.
The latest firmware for the AM4 platform, which is now being distributed as the final version by numerous mainboard manufacturers, poses major problems for many users. The manufacturer had continuously expanded its in-house program library for processors and chipsets, AMD Generic Encapsulated Software Architecture (AGESA), for the BIOS and UEFI developers of its board partners with new functions up to version v2 1.2.0.3c, but these suddenly disappear.
According to several feedbacks from the forum, the author's own tests with an AMD Ryzen 9 5950X on an MSI MEG X570 Unify, and several discussions on Reddit, installing AGESA ComboAM4v2 1.2.0.5 can lead to the following problems:
"Drops" of up to 100 MHz at the single core clock.
"Drops" of up to 150 MHz with the multi-core clock
Missing overclocking functions e.g. with PBO
A significantly cropped CBS/PBO menu
Performance problems with the second CCX
Low fabric clock (FCLK) possible
More WHEA-19 errors after OC
After a large part of the problems were previously due to the beta status of the firmware, some board partners have now released the firmware AGESA ComboAM4v2 1.2.0.5 as the final version for their motherboards. Depending on the manufacturer and mainboard, a "downgrade" from AGESA v2 1.2.0.5 to 1.2.0.3c is also not possible, which is why the latest firmware should only be installed with great caution and by experienced users.
For example, after MSI briefly had AGESA v2 1.2.0.5 online as the final BIOS, the manufacturer has now gone back to BIOS 7C35vAC1, which in turn is running under beta status. Other manufacturers such as Biostar and Gigabyte have already provided final BIOS updates with AGESA v2 1.2.0.5, but they sometimes struggle with the same problems. Significantly lower voltages and clock frequencies are also reported, for example. Meanwhile, Asus is taking a completely different approach. The manufacturer, after releasing several beta versions with AGESA v2 1.2.0.5, decided to proceed directly with AGESA ComboAM4v2 1.2.0.6b and not release final versions of its BIOS with AGESA v2 1.2.0.5 at all. Currently only Biostar, Gigabyte and MSI have final versions with AGESA v2 1.2.0.5 online, ASRock distributes beta versions and Asus is already preparing AGESA v2. 1.2.0.6b before. According to reports from the TweakTown forum, Gigabyte is already working on version 1.2.0.6.
Due to the current issues that may occur after installing the current version 1.2.0.5, the mature AGESA ComboAM4v2 1.2.0.3c is the safer choice and also offers all OC, CBS and PBO settings which are included in the new version was cropped. The various posts on Reddit, the Deskmodder website and in the ComputerBase forum provide further background information. "
Source (German): https://www.computerbase.de/2022-02/amd-ryzen-agesa-1205-firmware-probleme/
AGESA V2 PI 1.2.0.6b
what MSI gonna do about AGESA V2 PI 1.2.0.6b? realese date?
Need to be tested and modified so hard to say. With luck not long as they are working on a fix for us with the problem.
If it had affected systems with 16GB of ram problems would have been picked up way earlier
Hi, how do I know if I'm affected by the AGESA ComboAM4v2 1.2.0.5 bugs? My system has been stable, only thing I've noticed is my 5600x likes to throttle to 4.6 GHz @ 50c when idle, then down to 3.6 GHz @ 30c. I don't know why it's acting like it's underload all the time when it's just doing nothing. I have MSI Center installed and everything turned off inside the program, not sure if that can cause it. Chipset drivers are from the MSI site for my motherboard and not AMD. Do I need to take 1.2.0.6 when it comes out of beta even though I can't see anything wrong (though not 100% sure after reading the possible bugs).
I'm running the BIOS on the defaults, except for XMP which I enabled.
We must be careful when using the term "throttling". Throttling usually describes thermal throttling, meaning a temperature approaching 100°C or thereabouts, and the CPU trying to save itself by clocking lower. This is something completely different from the normal clock modulation in idle, or for cores that have nothing to do, which of course will clock down accordingly to save power.
The 4.6 GHz at 50°C would hint to the CPU not really being idle, but instead some background process causing load. This is most likely not related to the AGESA 1.2.0.5 bugs. When using MSI Center (a tool which i don't like), make sure it didn't mess with your power plans in Windows. The power plan should always be on Balanced or on Ryzen Balanced, never "High Performance" etc. Because contrary to their name, the "High Performance" and "Ultimate" power plans only cause higher power draw in idle, but can't really speed things up. When there is something to calculate for the CPU, it will immediately raise its clock speed again within nanoseconds, so Balanced is the way to go.
About the BIOS, yes, i would recommend the beta with AGESA 1.2.0.6b when it becomes available for your board. There are enough confirmed problems with 1.2.0.5 to warrant it.
Sorry, I'm a bit of a n00b when it comes to the different terms.
I've upgraded from Windows 10 to 11 and I've noticed that for the Power plan on Win10, it has "Ryzen balanced" and on Win11, it doesn't have that, just "Balanced". I wonder why?
MSI Center is removed now, as I came to realize that I won't use it's "features".
That beta BIOS is available for my MPG B550 Gaming Edge WiFi.
"7C91v191(Beta version)
Description
- Supporting upcoming CPU.
- Update to AMD ComboAm4v2PI 1.2.0.6b"
I don't know anything about going from a finalized stable BIOS to a fixed beta but if I encounter any issues (since beta's are still in development and could be buggy as they aren't in the official "finalized" status) could I just put the previous version on a USB stick and press the button on the motherboard?
I've been noticing something unusual though. When my system goes to "Sleep" (the power LED blinks) and I want to resume, normally I would just press a key on the keyboard but it doesn't always want to work that way and the only way I can "wake" my system is to press the power button. Would that be a bug in the BIOS?
I'm using an USB keyboard and I do have "Resume from USB" enabled in the BIOS.
Yes, try the beta. I think the Ryzen Balanced power plan was only necessary for Win10, on Win11 the "Balanced" might be enough.
Just put both BIOS versions on a USB stick and you can go back and forth between them like you want, via M-Flash in the BIOS. The Flash BIOS Button method is only for emergencies like, it doesn't want to boot at all anymore. Any kind of sleep issues can often be solved with a BIOS update, as they're heavily BIOS-dependant.
