MPG X570 Gaming Edge WiFi - Package Power table " unavailable " - E2 BIOS
Zooolz
MPG X570 Gaming Edge WiFi / 5900X
Utility applications failure to acquire information.
( HWinfo - ZenTimings .. etc .. )
5900X
G,Skill F4-4000C19 16GTZR (2x16)
Gforce 2070
All previous BIOS have Power Plan monitors working.
And, while I have your attention,,,
I been waiting for a " PPT limit " to actually work for my static OC.
( All Core = 45.5 multi @ 1.32v)
PBO set to Manual. 180 PPT ( desired )
However, when running Prime95 PPT is exceeded and no thermal protection working.
( over 210 PPT )
This problem has been present since I installed a 5900X
( Only EDC limit is working in ALL previous BIOS.)
1st Pic is E1 beta BIOS = it shows all the Package Power monitor values.
2nd Pic is E2 beta BIOS = missing values
Both show the PPT exceeding 200 PPT
Is there a tool to show the current BIOS package power values on the desktop ?
( to show BOTH actual VS. settings )
fatedust
Survey Corps
FIRST LIEUTENANT
Does issue only appear on 7C37v1E2(Beta version) but it disappears when flashing back to previous BIOS such as 7C37v1D?
Alan J T
And you really need to have another look at your Overclock as it is way over the top on power draw in comparison to what I have set for mine. and your CPU is supposed to have a better power efficiency.
Zooolz
Does issue only appear on 7C37v1E2(Beta version) but it disappear when flashing back to previous BIOS such as 7C37v1D?
Just E2 ( new )
I'm going to flashback to show HWINFO all default sensors ( screenshots )
" with ( E1 beta ) and / without ( E2 beta ) "
But, I just dont have the time to re-set my static OC in E1 beta now.
( I just installed a 6700XT and benching in E2 now )
My PPT limits NEVER worked in any BIOS with my static O/C
Zooolz
The issue is discussed here .... ZenTimings MSI error
I just didn't notice until Beta E2.
It seems to be AGESA 1.2.0.2 related (and maybe MSI).
Flashed back to Final E0 today --- only to see the same error ( my mistake )
ryegrass
Although I have a different motherboard than you, setting LCLK Frequency Control from disabled to (Auto), and
LCLK DPM Enhanced PCIe Detection to (Disabled) fixed the "can not get power table" for me on Agesa 1.2.0.2.
MPG X570 Gaming Plus 7C37vAD
