MPG X570 Gaming Plus -- Allow undervolting for 5800X3D
ecip
Tried it today but I have no access to core voltage settings...
anyone had any luck?
plutomate
MAJOR GENERAL
AMD allows no overclocking on 5800X3D
ecip
Yes. I know. This thread is not about overclocking. I'm looking to undervolt the core.
plutomate
MAJOR GENERAL
I believe changing vcore or CPU frequency in any way will be considered as "overclocking"
plutomate
MAJOR GENERAL
Until AMD decides to "unlock" this limitation, it's really not up to MSI to whether it is okay to open the option or not. I do know few ASUS motherboard enables vcore offset for 5800X3D, can't really say if it's "Legal" though.
Xentar712
There's a couple other threads where this has been discussed. There's quite a few people apologizing for MSI for leaving this feature locked. Lots of claims that it's due to AMD not allowing it and that it would cause chaos when motherboard companies will get blamed for AMD RMAs if something goes wrong.
I honestly don't get it. First why so many people think undervolting is dangerous, but more importantly why MSI would also be against it. The worst that could happen is you would get an unstable system if you wen too far and would need to reboot. They can also flash up all sorts of warnings and disclaimers about how "dangerous" it is, just like they do with overclocking, if they wanted.
It's not like it's stopping me either. I'm just using PBO2 tuner and applying a -30 to all the cores. Works fine and drops my temps over 10C. Trouble is, that's the lowest I can go with that software. It's also manual and needs to be done every time I boot.
I'm really hoping this is just a mistake on MSI's part and they open it up. I put in a ticket a couple weeks ago and it was subsequently closed with a note that the info was passed onto the appropriate team. There's no indication they will do anything about it so I'm not holding my breath. I'm giving it another month before I give up and potentially switch motherboards. Sounds tedious but I'd rather have voltage control of my CPU, especially since I plan on keeping this setup for another 2 years.
ecip
I remember reading a comment on a reddit post just the other day, mentioning that MSI is planning on allowing vcore manipulation in their next agesa update. So.... maybe there's something to it?
