MPG X570 GAMING PLUS Max amps for fan headers?
Nichrome
Active member
Hi
2A pump header
1A all other headers.
That's the safety rating, I suppose you could pull 1.2A or so... but wouldn't risk it.
ucnanoma4557062e
Hi
2A pump header
Nichrome
How did you find this information?
Do you know what these same header numbers are for
MPG Z390I GAMING EDGE AC ?
The only one it says is the 2.0A for the pump header.
Nichrome
Active member
Hi
It's a general knowledge. That's the case for all modern motherboards, unless something changed. Amps per fan header been like this for few years now.
ucnanoma4557062e
Sweet man thanks, I'm going to try my luck here in about 10 min see how it goes ... it's 0.55A so I hope we're right!
ucnanoma4557062e
Yup it worked like a charm! :)
Note to self, when your cpu is throttling, you need to get a fan that provides higher CFM or new heatsink.
This is great result for me, I can increase Pixel Density in DCS a bit more due to just cooling off my CPU more
Also bc it's 140mm fan, it's much quieter bc it gets those CFMs without too high of RPM.
