MPG x570 Gaming Pro Carbon USB-C 3.2 Gen 2: Does it have Alt Mode?
Seems
Does the USB-C 3.2 Gen 2 port on the rear panel of the MPG x570 Gaming Pro Carbon support DP Alt Mode?
Thanks!
Alan J T
🙈 🙉 Just 🐝 🤬😈
I guess you asking about Display Out if so then no is not thunderbolt Compatible Not sure how you even filtre out motherboards that are in search options May be best to go Intel if you need Thunderbolt 3 Support
