h.adanson155002d7
- Jan 16, 2024
Hello everyone,
I built new PC on MPG X670E CARBON,but having a serious problem still.
The sound become cracked and choppy and the frame rate of videos and games drops significantly.
It turns out that this problem can be reproduced under the following conditions.
1.GPU is installed to PCI-E
2. Audio driver is installed
The problem occurs when both 1 and 2 are met.
However, the problem does not occur when using only the iGPU.
Alternatively, uninstall the audio driver before shut down or restart, it will work fine without any issues, if GPU installed.
If install realtek USB Audio6.3.9600.2369 after uninstalled the audio driver and shut down , can boot normally.
Although I understand the rule, I don't know how to solve this problem.
The current BIOS is 7D70v18, but it doesn't help the 7D70v1C and 7D70v1E1 as they often had issues with PCI-E GPUs not being recognized and lost.
Thanks.
OS: windows 11 home
PSU: CORSAIR HX1000 1000W CP-9020139-JP
MB: MPG X670E CARBON
CPU: AMD Ryzen 7900X
DIMM: Corsair DDR5-5600MHz VENGEANCE 64GB (32GBx2) CMK64GX5M2B5600Z40 MM8194
GPU: Sapphire PULSE AMD Radeon RX 7800 XT 16G GDDR6
M.2-1 (boot): MSI SPATIUM M480 Pro PCIe 4.0 NVMe M.2 2TB S78-440Q600-P83 HD4391
M.2-3: ADATA 2TB PCIe Gen4x4 M.2 2280 LEGEND 800 series ALEG-800-2000GCSA
CPU cooler: DEEPCOOL LS720
Case: LIANLI O11 Vision
Others: Connect 6 case fans 120mm
*All settings related to OC are operated with ratings and defaults.
Thanks.
OS: windows 11 home
