MPG X870E EDGE TI WIFI Red CPU, Amber MB, code 46
kan692
When I turn on from day one Red CPU, Amber MB, code 46 it would take 2-5min to get the bios logo.
I had a few times it would hang up. Would turn it off back on and it would hang for 5min or more, then finally get the bios logo.
Now it just goes 00 then 46 and stops there. No video from motherboard or graphic card.
The only thing I did to it before this happened. Was put a new power supply and put new thermal paste on. It was fine for a few hrs till I turned it off and just hangs up now.
I took out all m.2, all drives, USB, tried with one stick of ram both of them in all slots, checked CPU all pins good and re-paste, up dated bios was on 7E59v1A33.
9900x3d
G.SKILL Flare X5 96GB (2 x 48GB) F5-6000J3036F48GX2-FX5
2070 super
1. Try clear CMOS by pressing Clear CMOS button on the rear panel of the mainboard for 5-10 seconds with PSU powered off and power cord unplugged.
2. Clean the memory module's golden finger with eraser and switch the memory module connected sequence or connect only one stick of memory module to try.
My friend from work is going to try the memory in his pc. Bring them to work tomorrow.
He thinks it might be something with the power supply that it worked all good one time and something just happened and looks like it working.
I got every thing out of the case if I have to send it back.
I got new memory coming that was on the QVL list.
So I think I'm going to try it all, old power supply, new ram, put old bios on after I retry the new one.
He just don't want to take his cpu out and up date his bios to see if it's the cpu. But we think it looks all good.
But I will check the memory slot and all out. Maybe I did get paste every were when I moved the block out of the way to check how it spread out.
Didn't think Kryonaut would be a problem. I was still really gooey for only being on there 3 months.
yea did it all.
My friend checked the memory said it worked.
Tried the memory single stick at a time in all slots, Bios 7E59v1A4, Clear CMOS button, waited 15-30min. Then Bios 7E59v1A41. Now trying 7E59v1A3 one last time since I was rushing it last nite.
Still same thing.
Looks like I'm going to have to wait till Tuesday, till the other memory comes to try. Was hopping it would come today so I could get it working and put back together so I could try the 9070xt Nitro+ out.
I tried the CPU, memory in another board and all worked fine. Then tried 7900x and single stick memory. Then started to get code 99 all the time. With just CPU and memory. So it I'm just going to have to send the board in for an RMA.
Got it back. It works with the 7900x and other memory. Now just need to switch motherboards around see how it goes. But m.2 screw and heat back plate came off in shipping and put 2 small scratches on the heat plate. Don't look like any other damage. Didn't even know the back plate came off. I guess that how you would put a different m.2 size in the first slot.
