MPG Z490 Edge wifi OC went to Defalut on its own how can i oc again?
fires
PRIVATE FIRST CLASS
I was clocked @4.8  and every thing was fine until i changed my screen resalution from  2560X1440  To  3200X1800
the next thing i know is the pc restarted and there was no more OC Profile
now its back @ 3.8
and i dont know how to get it back to 4.8
help me  :)
thanks
Nichrome
Active member
Hi
That suggests your OC was unstable and system crashed. If you didn't save the OC as a profile, then most likely you need to re-do it.
fires
PRIVATE FIRST CLASS
Nichrome date=1593856890 said:
Hi
Yes Correct
But i cant seam to do it again
what should i do to OC the mobo again ?
thank you
darkhawk
Active member
You need to go into your overclock settings and change the CPU multiplier to 48.
fires
PRIVATE FIRST CLASS
Thanks for the help
but some how it just kicked in on its own :)
