Hi everyone,
I'm having an intermittent resume failure on my system and would appreciate any help.
System
- Motherboard: MSI MPG Z490 GAMING PLUS, BIOS 7C75vAF1 (latest available)
- CPU: Intel Core i7-11700K (using the integrated UHD 750, no discrete GPU)
- RAM: Kingston FURY 32GB (2x16GB) DDR4-3600 kit, installed in DIMMA2 and DIMMB2
- System drive: Samsung 250GB SATA SSD (the only storage device used as boot drive)
- PSU: tested with both Antec 650W and Seasonic 1200W (8-pin + 4-pin CPU power both connected)
- OS: Windows 11 26H2
- Intel ME driver and iGPU driver: latest versions
Problem
Sometimes when resuming from sleep (S3), and also from hibernate (S4), the PC does not come back:
- Monitor shows "No signal"
- Case fans and drives are spinning
- Num Lock / Caps Lock do not respond
- I have to hold the power button to force shutdown. On the next boot the system starts normally (and the hibernate image is restored fine).
- It is intermittent, not every time.
- Cold boot from a full shutdown has never failed.
Key observations
- When the failure happens, the EZ Debug LED shows the **CPU LED stays on**.
- Event Viewer: Kernel-Power Event 41 with BugcheckCode 0 (no BSOD, the system just hangs).
- Since hibernate also fails, I don't think this is caused by RAM self-refresh during S3.
What I have already tried (problem still occurs)
- Updated to the latest BIOS, Intel ME driver and iGPU driver
- XMP disabled (RAM at default 2400 MHz), problem remains; it also occurred with XMP at 3600
- Memory Fast Boot: Disabled
- ErP Ready: Disabled
- DRAM Power Down Mode: Disabled
- Intel C-State: Disabled
- Two different PSUs (650W and 1200W) with the CPU power connectors fully populated
Another symptom
After I loaded BIOS defaults once and saved, the PC shut down and the power button did nothing. It only recovered after unplugging the PSU and holding the power button for about 30 seconds.
Questions
1. Is a CPU LED stuck on during resume a known issue with Z490 boards running an 11th gen CPU (Rocket Lake)? Is there a BIOS version known to fix resume problems with 11th gen?
2. Are there any BIOS settings (CPU power, PCIe/ASPM, microcode related) I should try?
3. Does this look more like a BIOS/microcode problem, or a CPU/VRM hardware fault that I should RMA?
I can provide more details or logs (powercfg /sleepstudy, event logs) if needed. Thanks in advance!
System
Problem
Key observations
Another symptom
Questions
