MSİ X470 GAMİNG CARBON PRO ANAKARTIN 4133 MHZ BELLEK DESTEĞİ
Mega_Hydranoid123
Merhabalar Benim Anakart x470 Gaming Pro Carbon Olan Anakartımın 5. Nesil İşlemci Desteği Kaldırıldı mı Biostan Baktım Eskiden Vardı Şuanda Yok 5.nesil AMD RYZEN 5 5600x yada AMD RYZEN 7 5800x İşlemci Alacağım ve Bu İşlemcilerle Bu Anakartla 4133 Mhz Ram Destekler mi Yoksa Yeni Anakart mı Almalıyım b450 ler Bilene Destek Veriliyorken Benim Anakartta Niye Bu Destek Verilmiyor Sizden Bilgi İstemekteyim
Alan J T
🙈 🙉 Just 🐝 🤬😈
Hello, My Motherboard is x470 Gaming Pro Carbon. Has the 5th Generation Processor Support been Removed? Should I Buy B450s While Support Is Provided To Anyone Who Knows Why Isn't This Support Provided On My Motherboard? I Ask You For Information
There is no gen 5 CPU for the AMD board so are you by chance asking about a z470 intel board, List all your hardware please
Mega_Hydranoid123
Hello, My Motherboard is x470 Gaming Pro Carbon, Does it Support 5th Generation Processor Or I Looked In The Bios It Used To Remove It, There Is Now There Is No 5.sil AMD RYZEN 5 5600x or AMD RYZEN 7 5xx I will buy and with these processors, this motherboard will support 4133 Mhz RAM or is it a new motherboard? While Support is given to those who know b450s to buy, why is this support not given on my motherboard? I ask you for information.
badboy2k
x470 Gaming Pro Carbon supports:
RYZEN 9 5950X
RYZEN 9 5900X
RYZEN 7 5800X
RYZEN 5 5600X
all need BIOS 7B78v2H.zip
and Technically they are 3rd Gen Ryzen CPU's
as for RAM speed that is down to how good the IMC (Memory Controller) in the CPU is
Alan J T
🙈 🙉 Just 🐝 🤬😈
That would be a no go on the Ram it is not supported and ya AMD could have done a better naming system on the CPU range
3969274115a202e1
RYZEN 9 5950X
RYZEN 9 5900X
RYZEN 7 5800X
RYZEN 5 5600X
Why is there no download link of 7b78v2h.zip on the official website
bschalker
CORPORAL
I think MSI has pretty much abandoned X470 and B450 motherboards. This motherboard, I have it as well, did not get a final bios ever since 22-06-2020 that was based on AGESA V1 still. Also on top of that every other brand, like Gigabyte, Asus, Asrock, they have all updated their X470 and B450 motherboards already to AGESA 1.2.0.3 Patch B. MSI seems to not be updating the X470 and B450 motherboards to this BIOS. Also it takes MSI incredibly long to roll out new BIOS versions. I am loosing a bit of faith in this company.
darkhawk
I just wish AMD had a clue how to actually make a 'good' base BIOS for OEM's......then we wouldn't have so many problems. They can't seem to even get a decent base code out, why expect OEM's to get something out even better then?
AMD has a very poor BIOS system, and honestly, any software engineer that looks at it would be appalled in general by the situation.
