- May 20, 2011
Hi everybody, I am having a strange problem I hope you all can help me with. I am getting a double boot issue, when I start up the computer, it gets stuck at code 69 (late north bridge initialization), then reboots. This is where it gets strange - upon reboot, the computer passes the point where the BIOS loads, then boots to a black screen - it will not load the OS (or boot from a CD or a USB drive for that matter) no matter what I try.
The problem seems to be correlated with RAM. The first RAM I had on this system was http://www.newegg.com/Product/Product.aspx?Item=N82E16820220535, I ran with X.M.P. enabled (at 1866, since this RAM was 2000), and had the issue described above. Went ahead and tried it at 2133, disabled X.M.P., loosened the timings, and bumped the voltage up to 1.7v - still a no go. So I re-enabled X.M.P., lowed the voltage back to 1.65v, and tried 1600. It worked, and that is how I was using the computer for almost 2 months with no problems. This weekend, RAM went on sale at newegg, so I sprung for some 1.5v RAM, thinking that might be the issue. I bought http://www.newegg.com/Product/Product.aspx?Item=N82E16820233142, which says it is optimized for Sandy Bridge systems. Well I tried all the steps I did with the other RAM, and its still a no go. I am running currently at 1.5v, with X.M.P. enabled, at 1600 (default it 1866).
P.s. This was happening with BIOS 1.0, so I upgraded to 1.1 with no problems, but the problem is still there.
I hope you guys can help me troubleshoot this problem, because I am at a loss here. Thanks in advance for all your help.
-Frank
-Frank
