MS-8348 problems
magundy
I just got a MS-8348 and it is incorrectly seeing the
speed the disks should be able to write on.
Princo disks that are 2x-48x, and the MS-8348
says that they are 16x Max.
Imation disks that are 12x and the MS-8348
Old Sony 6x disks and the MS-8348
Nero reports Firmware Revision: A.QZ
My 24x Aopen burner reports that it can burn the
Princo at 24x and the Imation at 12x
The only media that the MS-8348 recognizes as other
than 16x is the disk that came with the burner.
magundy,
Is your drive the MS-8348A or the MS-8348B?
Also what is the other hardware in your comp and the OS you are running?
Richard
MS-8348B
This is not related to hardware in my computer,
or the OS.
This is a problem with the drive recognizing the media.
Searching through your site I have seen firmware upgrades for other burners that seem to be primarily to
recognize more types of media.
When will MSI be putting up a firmware upgrade.
Simply allowing the drive to burn at 16x to any
unrecognized media is not acceptable, when the
drive is unable to recognize most types of media.
I am having the exact same problem.
When will a firmware upgrade come out to solve this obvious problem.
