ChickenNuggetNinja
- Apr 2, 2026
Hi everyone, I recently got my MSI 341CQPX QD-OLED monitor (replacement unit, 14 days old).
I’ve noticed uneven vertical banding specifically on the right corner of the screen.
I’ve already tried panel protect, power cycling, and replacing the DP cable, but nothing helps.
I even waited for 100–150 hours of usage (break-in period), but the issue is still visible.
Is this normal for QD-OLED panels, or should I consider this a defect worth sending back for RMA?
Has anyone here had success with RMA approval for similar uneven banding issues?
