Msi 8850 and fsb need help,pls
  • Thread starter Thread starter borab
  • Start date Start date
B
borab
Guest
I have Msi 8850 and asus tusl2-c mobo.Everything is just fine.So , I tried to cd my cpu t fsb 124Mgh, but i had 8 bits palete in Win ME, so I conlcuded taht vga card can not work at that fsb.Is this correct.Before Msi I had inno gf3mx400 and everything was fine.
borab,
Not sure if I am following what you are saying. Could I get the full specs of your system? The ASUS Board is the i815 chipset which runs at 133Mhz FSB, are you underclocking it or do you have a PIII with a 100Mhz FSB?
To answer your question on the GeForce 3, it does not use the FSB. It uses the AGP Bus which is suppose to be at 66Mhz. nVidia's graphics cards are disigned to run at 66Mhz have been known since the GeForce 256 to run with an AGP running at 89Mhz since the days of overclocking the old 440BX motherboards with a FSB of 133Mhz.
Richard
