jmarkgalvez0158502e3
- Jun 16, 2024
Thank you so much, really appreciate it man!That board is from a pre-built PC, it has different BIOS updates than the retail board: https://www.msi.com/Motherboard/A320M-PRO-E/support
.Ixx vs .Hxx
Two options:
1) Cross-flash the retail board's BIOS (from above) using this forum flash tool.
Or:
2) Flash the last available BIOS for your non-retail board, E7A36AMS.I41, get it from here where it says "E7A36AMS.I41 (AGESA 1.2.0.B)".
Hello, I'm having the same issue. Does this last version support the Ryzen 5 5500? I knew my mobo is compatible with my new CPU, but I never knew that there would be a different OEM BIOS.That board is from a pre-built PC, it has different BIOS updates than the retail board: https://www.msi.com/Motherboard/A320M-PRO-E/support
.Ixx vs .Hxx
Two options:
Or:
I can't update my BIOS from the official website of MSI because I think my motherboard came from a prebuilt system. That's why if the E7A36AMS.I41 which is the latest BIOS update from the OEM company is compatible with the Ryzen 5 5500.View attachment 189523
The latest one on website has AGESA 1.2.0.A and it already supports 5000 CPU. The beta on google site has AGESA 1.2.0.B so it should support 5000 CPU as well.
Well, what I need is BIOS version that will support my new Ryzen 5 5500 CPU. And I'm not getting an answer if that version is compatible with it.Go with I41 BIOS, nothing to worry about, it's been proved working by other people![]()
